Старый 07.05.2019, 15:49   #22749
Panzerschreck
Аватар для Panzerschreck
Был(а): 2025-02-22 20:19
По умолчанию Re: Бензин или дизель?
Сообщение от kval300
Но то что у него дизельный момент -брехня,на низах,пусть термех в начале почитают или изучат
Может, стОит самому за парту?
t will be available in three different configurations, starting off with the base Energy TCe 115 flavor set to produce 115 horsepower (85 kilowatts) at 4,500 rpm and a maximum 162 pound-feet (220 Newton-meters) of torque that will kick in from 1,500 rpm. You should know that this entry-level version will be teamed up exclusively with a six-speed manual gearbox whereas the other two will be optionally available with a seven-speed EDC.
The midrange Energy TCe 140 offers 140 hp (103 kW) at 5,000 rpm and 177 lb-ft (240 Nm) from 1,600 rpm regardless of gearbox selection. For those in need of more power, the Energy TCe 160 delivers 160 hp (120 kW) at 5,500 rpm and 192 lb-ft (260 Nm) from 1,750 Nm when hooked up to the manual transmission. Go for the EDC and you’ll get an extra 8 lb-ft (10 Nm) for a total of 200 lb-ft (270 Nm) that will be attainable slightly later in the rpm range, at 1,800 rpm.
An interesting fact about the three-in-one TCe gasoline engine is represented by its cylinder coating technology borrowed from the Nissan GT-R’s engine. According to Renault, it has boosted efficiency by diminishing friction and optimizing heat transfer. Not only that, but the four-cylinder boasts something called Dual Variable Timing Camshaft, which improves low-end torque and grants a more linear torque delivery at higher rpms.
С переводом надо помочь?
https://www.motor1.com/news/223884/r...soline-engine/
А тут для наглядности сводная табличка
https://www.planeterenault.com/1-gam...15140160-h5ht/
Но скорее всего одноразовый- ресурс оценивается в 220000 км.
Отмечен прогрессирующий жор масла.
https://otoba.ru/dvigatel/renault/h5ht.html
